Alert: Export Control Check Required
Thank you for requesting a TWI Industrial Members Report.
To meet UK government requirements, your request will undergo an Export Control Check. This process reviews the technical content of the report, identifies the end user, and addresses any concerns.
Please submit your request to CRP@twi.co.uk including your name, member company that you work for and your location. We will contact you regarding the request within 2 working days and any additional information required to complete the necessary checks.
We look forward to receiving your request and processing it through our export control procedure.
Thank you,
TWI CRP Operations Team
This content is only available to Industrial Members, Find out how to become a Member of TWI.
TWI Industrial Member Report Summary 1064/2015
By Henry Begg and Melissa Riley
Prior to the application of coatings and paints, substrates are often grit blasted to roughen the surface and provide a mechanical key with which the coating can bond. The strength of the bond is highly dependent on cleanliness and roughness. This surface is generally prepared by grit blasting, which is often a manual process with little process control/monitoring and relies heavily on operator skill and judgement. Recent mechanised blasting operations at TWI have indicated that measurement and control of blasting parameters are vital to coating performance.
Key Findings
A large-scale parameter study was undertaken encompassing:
- Seven metallic substrates (CoCr alloy ASTM F75, Ti-6Al-4V, UNS N07718 Ni alloy 718, UNS S30400 304-grade stainless steel, BS EN10025 S355 steel, AA 6055-T4 Al alloy and copper),
- Eight blasting variables (grit size; blast pressure; media feed rate; stand-off distance; blast angle; number of passes/scanning increment/robot traverse speed).
- Over 35 surface profilometry parameters with 7 selected for more detailed analysis including peak height (Sa, Sz, Ra), peak distribution and shape (Ssk, Sku), a peak spacing (RSm) and a peak slope (Sdq) parameters
Some key findings of the work include:
- Changes to blast media size and blast pressure have a strong influence on substrate roughness.
- Standoff distance and blast media feed rate have a more limited effect on substrate profile than expected.
- Grit blasted surface profile is strongly affected by substrate alloy composition, with Ti-6Al-4V exhibiting anomalously high levels of embedded alumina abrasive.
- Standard average roughness profilometry parameters (Ra and Sa) are recommended for providing consistent, repeatable information on profile heights.
- More advanced profilometry parameters such as Ssk, Sku and Sdq can provide valuable information on characterisation of under and over-blasted surfaces.
Print version
