Failure Investigation: Services and Support
There are often many possible reasons why engineering components fail in service, meaning that the cause and mechanisms of failure can only be determined with the right combination of analytical equipment and experienced engineers.
Failure analysis is when an investigation takes place to determine the cause of failure, usually with the aim of taking corrective action to fix the problem and mitigate against further failures. Failure analysis is undertaken across all branches of manufacturing industry to prevent future asset and product fails as well as protecting against potentially dangerous risks to people and the environment. Failure analysis covers a range of industrial assets, such as pressure vessels, for example, and investigates different failure modes, such as fracture surfaces or manufacturing-based issues.
Reasons to Perform Failure Analysis Testing
The failure analysis process provides a number of benefits including financial, legal and safety related outcomes:
Understand Root Cause of Failure
Understanding the root cause is often the fundamental part of an accident investigation or failure analysis process. This root cause analysis involves data collection to ascertain whether failure occurred due to manufacturing or material defect or misuse.
Prevent Asset or Product Failures
Once the cause of failure has been determined corrective actions can be taken to prevent a recurrence of the problem.
Improve Future Products and Processes
Manufacturing processes and product designs can be improved due to an understanding of the failure mode, not only to prevent the problem from happening again but also to prevent costly legal action or replacements as well as protecting a company's reputation.
Prevent Financial Losses and Penalties from Failed Components
Failure can be costly, whether due to expensive outages, a stopping of production, or even legal action as a result. Undertaking failure analysis can prevent these problems from growing or potential failures from happening in the future as a result of the same failure mechanisms.
Meet Standards for Products and Assets
Failure mode and effects analysis can help to meet standards for manufacturing processes, failed components, products, or assets going forward.
Determine Liability for Failure
A failure analysis will not only determine the root cause leading to failure, but may also assign liability for the failure. This can be used in legal proceedings to not only apportion blame but also protect yourself from litigation. This may require the use of additional case studies, forensic engineering or expert witness testimony.
Whatever the nature of the failure, and however small or large the part, TWI has the capability and the experience to respond quickly and carry out a conclusive investigation into what went wrong.
There are often many possible reasons why engineering components fail in service, meaning that the cause and mechanisms of failure can only be determined with the right combination of analytical equipment and experienced engineers. As such, we can assemble a team of engineers tailored precisely to the nature of the material, application and service conditions, to identify the cause and recommend appropriate steps to minimise the risk of a reoccurrence.
For more information on how TWI can help, please email:
Our Methodology
Over the last 60 years, TWI has conducted thousands of failure investigations for some of the world’s largest industrial companies. Every project is undertaken in strict confidence, often beginning with an on-site failure assessment before more thorough laboratory testing is carried out at one of TWI’s fully equipped facilities.
The failure analysis process often involves:
  • Interpretation of the failure location and service data, including on-site review
  • Examination of the parts to determine the failure mechanism(s)
  • Engineering root cause, including design, fabrication, transportation, installation and service
  • Simulation of the service conditions to establish critical parameters at which failure will occur
  • Definition of safe conditions for remaining intact components
  • Establishment of a non-destructive evaluation strategy for remaining components
  • Remedial advice for the avoidance of further failures, including design and fabrication reviews for replacement components and mitigation strategies for existing components.
As and when required, this process is supported by the application of related testing and analysis systems:
  • Bespoke or standard mechanical testing by our mechanical engineers
  • Corrosion or aggressive environment testing
  • Chemical analysis, including hydrogen measurement
  • Fractrography
  • Metallography
  • Non-destructive testing
  • Advanced scanning electron microscopy
Insights
Find out more about failure investigation at TWI:
Core Research
Each year the TWI Core Research Programme (CRP) addresses challenges on behalf of our Industrial Members as well as developing specific technologies and processes. Each of the projects under the CRP is focussed on engineering, materials or manufacturing technologies, including failure investigation.
Joint Industry Projects
TWI also conducts Joint Industry Projects (JIPs) that bring together groups of Industrial Members to share the cost of research activities in areas of mutual industrial interest, gaining exclusive access to the outcomes. These projects cover a broad range of topics, including failure investigation.
TWI Failure Investigation Support
A full list of our testing and analysis systems can be found here.
Through the combination of the specialist expertise of our engineering teams and our access to cutting-edge technology, TWI can provide the right information to asset operators or other interested parties in the right time frame.
TWI has both the state-of-the-art facilities to carry out complex failure investigations and the expertise to interpret the results and offer the solutions to avoid further failures in the future.
