Acoustic Emission Testing Services
Acoustic emission testing is a non-destructive testing (NDT) technique used to detect, locate, and monitor structural defects such as cracks, leaks, and corrosion in real-time. Acoustic emission (AE) works by ‘listening’ to high-frequency stress waves (between 20 kHz and 1 MHz) that are released when materials deform or fracture.
When a component is stressed enough to create defects through factors such as pressure loading or heat, energy is released as transient elastic waves that travel to the surface. These waves can be passively detected by piezoelectric sensors. AE can detect and locate active defects, growing damage during operation, or provide proof tests in real time, allowing for immediate assessment before failure occurs.
Commonly used for applications including the inspection of pressure vessels, storage tanks, bridges, pipelines, or detecting fibre breakage in composites, AE can provide a full scan of complex structures.
Press Releases
Find out more about acoustic emission testing at TWI:
Core Research
Find out more here
Joint Industry Projects
Find out more here
Acoustic Emission Testing at TWI
Acoustic emission testing is one of several areas of non-destructive testing expertise available at TWI. We provide guidance and support in the use of the technology as well as undertaking AE-related projects and testing on behalf of our Industrial Members.
We can operate acoustic emission testing services in line with applicable standards such as ASTM E3100-17 (which covers concrete applications) and BS ISO 16837:2019 (which covers general NDT applications). Alternatively, we can create and run bespoke testing regimes to suit your exact industrial needs.
As TWI is an independent and impartial organisation that works across all industry sectors, our Industrial Members can be assured that we will deliver the best solution for their needs.
To find out more about acoustic emission testing or NDT services at TWI, please email contactus@twi.co.uk.
