Radiography Testing - NDT Inspection
Radiographic testing (RT) is a non-destructive testing (NDT) method which uses either X-rays or gamma radiation to examine the internal structure of manufactured components, identifying any flaws or defects.
In radiography testing, the test-part is placed between the radiation source and film (or detector). The material density and thickness differences of the test-part will attenuate (i.e. reduce) the penetrating radiation through interaction processes involving scattering and/or absorption. The differences in absorption are then recorded on radiographic film(s) or through an electronic means as a latent image. In industrial radiography there are several imaging methods available; techniques to display the final image, i.e. film radiography, real time radiography (RTR), computed tomography (CT), digital radiography (DR), and computed radiography (CR).
There are two different radioactive sources available for industrial use; X-rays and gamma-rays. These radiation sources use higher energy level, i.e. shorter wavelength, versions of the electromagnetic waves. Because of the radioactivity involved in radiography testing, it is of paramount importance to ensure that the Ionising Radiation Regulations (2017) and site specific local rules are strictly adhered to during operation to ensure radiation safety.
Computed tomography (CT) is one of the lab-based advanced NDT methods that TWI offers to industry. CT is a radiographic based technique that provides both cross-sectional and 3D volume images of the object under inspection. These images allow the internal structure of the test object to be inspected without the inherent superimposition associated with 2D radiography. This feature allows detailed analysis of the internal structure of a wide range of components.
TWI Projects
We have completed a range of projects related to radiographic testing on behalf of our Industrial Members. Past radiographic testing-related projects, include:
NDT Press Releases
Find out more about NDT at TWI:
Core Research
Each year the TWI Core Research Programme (CRP) addresses challenges on behalf of our Industrial Members, as well as developing specific technologies and processes. Each of the projects under the CRP is focussed on engineering, materials or manufacturing technologies, including radiographic testing. Past radiography CRP research includes, ‘Feasibility of Using Laser Profiling for Image Enhancement of Digital Radiographs,’ which addressed the opportunity to improve analysis through automated defect recognition (ADR) software.You can see more about this project here (Industrial Members can login and view the full report):
The use of polyethylene (PE) has increased in the water and gas industries over the past two decades. This article explains why, and highlights the need and development of reliable NDT techniques.
Joint Industry Projects
We also conduct Joint Industry Projects (JIPs) that bring together groups of Industrial Members to share the cost of research activities in areas of mutual industrial interest, gaining exclusive access to the outcomes. These project cover a broad range of topics, including the use of radiographic testing to help assess the adoption of handheld laser welding technology by industry. You can see more about this project, here:
IntACom 4.0 aims to revolutionise inspection methods, particularly for composites and thin metals.
To find out more about NDT services at TWI, email:
Radiography Testing at TWI
TWI provides a range of radiography testing and support services for our Industrial Members, both in the UK and overseas. Our facilities include the following radiography equipment, with the capability to cater for film radiography, real time radiography (RTR), computed tomography (CT), digital radiography (DR) and computed radiography (CR) for industrial needs:
  • Comet MXR-451/26 450kV system
  • GemX-160 160kV portable system
  • X-Tek Industrial 450 kV micro-focus system
  • NSI X5000 240kV micro-focus CT system
  • Nikon 450kV micro-focus CT system
  • Nikon HMX-225 micro-focus CT system
Benefits
As a testing technique, radiography provides a number of benefits for industry, such as:
  • Can inspect assembled components
  • Minimum surface preparation required
  • Potential to detect both surface and subsurface defects
  • Provides permanent records of the inspection
  • Able to verify internal flaws on complex structures
  • Capability to isolate and inspect internal components
  • Automatically detect and measure internal flaws
  • Measure dimensions and angles within the sample without sectioning
  • Sensitive to changes in thickness, corrosion, flaws and material density changes
Applications
Radiographic testing is widely used for a range of inspection tasks, including weld inspection, for:
We also offer training in radiographic testing.
For more information about TWI's radiography testing or NDT services, please email contactus@twi.co.uk.
