What is Non-Destructive Testing (NDT)? Methods and Definition
NDT stands for non-destructive testing and is also known as non-destructive examination (NDE), non-destructive inspection (NDI) and non-destructive evaluation (NDE).
Non-destructive testing (NDT) is a testing and analysis technique used by industry to evaluate the properties of a material, component, structure or system for characteristic differences or welding defects and discontinuities without causing damage to the original part.
This frequently asked question has been created to provide a breakdown of what NDT is, an introduction to each of the methods, the difference between NDT and destructive testing and the advantages of using this analysis technique.
Non-destructive Testing at TWI
Non-destructive testing (NDT) includes a wide range of testing and analysis techniques used across industry to evaluate the properties of a material, component, structure or system for any issues without causing damage to the original part.
TWI provides NDT services for a variety of industry sectors alongside research and development of NDT technologies, processes and inspection services. We carry out hundreds of NDT projects for our Industrial Members each year to ensure that equipment, plant assets and products remain operational, reliable and safe.
Projects
Our team of highly skilled engineers and technicians, coupled with our wide range of industrial facilities and tools, allows us to solve the NDT problems of our Industrial Member companies. NDT projects undertaken at TWI include:
NDT Press Releases
Find out more about NDT at TWI:
Core Research
Each year the TWI Core Research Programme (CRP) addresses challenges on behalf of our Industrial Members as well as developing specific technologies and processes. Each of the projects under the CRP is focussed on engineering, materials or manufacturing technologies, including Non-destructive Testing (NDT).
The use of polyethylene (PE) has increased in the water and gas industries over the past two decades. This article explains why, and highlights the need and development of reliable NDT techniques.
Joint Industry Projects
TWI also conducts Joint Industry Projects (JIPs) that bring together groups of Industrial Members to share the cost of research activities in areas of mutual industrial interest, gaining exclusive access to the outcomes. These projects cover a broad range of topics, including NDT, such as the ‘IntACom 4.0 – Advanced Non-Destructive Inspection’ project that is revolutionising NDT, particularly for composites and thin metals.
IntACom 4.0 aims to revolutionise inspection methods, particularly for composites and thin metals.
To find out more about NDT services at TWI, email:
Contents
Click the links below to skip down to a section in the guide:
Non-Destructive Testing Methods
Current NDT test methods include:
Acoustic Emission Testing (AE)
Acoustic emission testing
This is a passive NDT technique, which relies on detecting the short bursts of ultrasound emitted by active cracks under a load. Sensors dispersed over the surface the structure detect the AE. It is even possible to detect AE from plasticisation in highly stressed areas before a crack forms. Frequently a method for use during proof tests of a pressure vessel, AE testing is also a continuous Structural Health Monitoring (SHM) method, for example on bridges. Leaks and active corrosion are detectable AE sources too.
Learn more
Electromagnetic Testing (ET)
This testing method uses an electric current or magnetic field which is passed through a conductive part. There are three types of electromagnetic testing, including eddy current testing, alternating current field measurement (ACFM) and remote field testing (RFT).
Eddy current testing uses an alternating current coil to induce an electromagnetic field into the test piece, alternating current field measurement and remote field testing both use a probe to introduce a magnetic field, with RFT generally used to test pipes.
Ground Penetrating Radar (GPR)
This geophysical NDT method sends radar pulses through the surface of a material or subsurface structure, such as rock, ice, water or soil. The waves are reflected or refracted when they encounter a buried object or material boundary with different electromagnetic properties.
Learn more
Laser Testing Methods (LM)
Laser testing falls into three categories including holographic testing, laser profilometry and laser shearography.
Holographic testing uses a laser to detect changes in the surface of the material which has been subjected to stress such as heat, pressure or vibration. The results are then compared to an undamaged reference sample to show defects.
Laser profilometry uses a high speed rotating laser light source and miniature optics to detect corrosion, pitting, erosion and cracks by detecting changes in the surface via a 3D image generated from the surface topography.
Laser shearography uses laser light to create an image before the surface is stressed and a new image is created. These images are compared to one another to determine if any defects are present.
Leak Testing (LT)
Leak testing can be broken down into four different methods - bubble leak testing, pressure change testing, halogen diode testing and mass spectrometer testing.
Bubble leak testing uses a tank of liquid, or a soap solution for larger parts, to detect gas (usually air) leaking from the test piece in the form of bubbles.
Only used on closed systems, pressure change testing uses either pressure or a vacuum to monitor the test piece. A loss of pressure or vacuum over a set time span will show that there is a leak in the system.
Halogen diode testing also uses pressure to find leaks, except in this case air and a halogen-based tracer gas are mixed together and a halogen diode detection unit (or 'sniffer') is used to locate any leaks.
Mass spectrometer testing uses helium or a helium and air mix inside a test chamber with a 'sniffer' to detect any changes in the air sample, which would indicate a leak. Alternatively, a vacuum can be used, in which case the mass spectrometer will sample the vacuum chamber to detect ionised helium, which will show that there has been a leak.
Magnetic Flux Leakage (MFL)
This method uses a powerful magnet to create magnetic fields which saturate steel structures such as pipelines and storage tanks. A sensor is then used to detect changes in magnetic flux density which show any reduction in material due to pitting, erosion or corrosion.
Microwave Testing
This method is restricted to use on dielectric materials and uses microwave frequencies transmitted and received by a test probe. The test probe detects changes in dielectric properties, such as shrinkage cavities, pores, foreign materials or cracks and displays the results as B or C scans.
Liquid Penetrant Testing (PT)
Liquid penetrant testing involves the application of a fluid with low viscosity to the material to be tested. This fluid seeps into any defects such as cracks or porosity before a developer is applied which allows the penetrant liquid to seep upwards and create a visible indication of the flaw. Liquid penetrant tests can be conducted using solvent removable penetrants, water washable penetrants or post-emulsifiable penetrants.
Magnetic Particle Testing (MT)
Also known as magnetic particle inspection, this NDT process uses magnetic fields to find discontinuities at or near the surface of ferromagnetic materials. The magnetic field can be created with a permanent magnet or an electromagnet, which requires a current to be applied.
The magnetic field will highlight any discontinuities as the magnetic flux lines produce leakage, which can be seen by using magnetic particles that are drawn into the discontinuity.
Neutron Radiographic Testing (NR)
Neutron radiography uses a beam of low energy neutrons to penetrate into the workpiece. While the beam is transparent in metallic materials most organic materials allow the beam to be seen, allowing the structural and internal components to be viewed and examined to detect flaws.
Radiographic Testing (RT)
Digital Radiography
Radiographic testing uses radiation passed through a test piece to detect defects. X-rays are commonly used for thin or less dense materials while gamma rays are used for thicker or denser items. The results can be processed using film radiography, computed radiography, computed tomography or digital radiography. Whichever method is used, the radiation will show discontinuities in the material due to the strength of the radiation.
Learn more
Thermal/Infrared Testing (IRT)
Infrared testing or thermography uses sensors to determine the wavelength of infrared light emitted from the surface of an object, which can be used to assess its condition.
Passive thermography uses sensors to measure the wavelength of the emitted radiation and if the emissivity is known or can be estimated, the temperature can be calculated and displayed as a digital reading or as a false colour image. This is useful for detecting overheating bearings, motors or electrical components and is widely used to monitor heat loss from buildings.
Active thermography induces a temperature gradient through a structure. Features within it that affect the heat flow result in surface temperature variations that can be analysed to determine the condition of a component. Often used to detect near surface delaminations or bonding defects in composites.
Learn more
Ultrasonic Testing (UT)
Ultrasonic Testing entails the transmission of high frequency soundwave into a material to interact with features within the material that reflect or attenuate it. Ultrasonic testing is broadly divided into Pulse Echo (PE), Through Transmission (TT) and Time of Flight Diffraction (ToFD).
Learn more
Pulse Echo Inspection
This NDT inspection technique introduces a sound beam into the test material surface. The sound will travel through the part, either reaching the rear wall of the material and then returning to the transducer or returning early when reflected from a discontinuity within the part. If the acoustic velocity is known, the time interval recorded is then used to derive the distance travelled in the material.
Through Transmission Testing
TT uses separate transducers to emit and receive the sound. The transmit probe is positioned one side of the test sample and the receive transducer is positioned on the other side. As the sound passes through the component, it is attenuated by features within it, such as porosity. Thickness measurement is not normally possible with this technique.
Diffraction is the process of a change in wavelength in sound as it interacts with a discontinuity in a material. This mechanism is used in situations where a true reflection cannot be obtained but sufficient diffraction occurs to alter the time of flight of the sound in a pitch-catch arrangement. This method is used to detect the tip of a defect that resides perpendicular the probe contact surface. ToFD is also used for rear wall inspection for detection of corrosion.
Immersion Testing
The requirement to wet couple the ultrasound probe to the part can be a challenge for large or complex geometric samples. For convenience these parts are immersed in water – typically in an immersion tank. This method is usually enhanced by actuators that move the part and/or the probe within the tank during ultrasonic inspection.
Learn more
Air Coupled Testing
Certain inspections and materials cannot tolerate the application of wet coupled and so in certain circumstances air coupled ultrasound testing may be performed. This entails the application of sound through an air gap. This typically entails the use of lower frequency inspection.
Electromagnetic Acoustic Transducer (EMAT) Testing
EMAT Testing is a type of non-contact inspection method that uses electromagnetic sound generation and reception without immediate contact or wet coupling with the part. EMATs are of particular use for excessively hot, cold, clean, or dry environments. As with conventional ultrasound, EMATs can produce normal and angled beams as well as other modes, such as guided waves.
Guided Wave Testing (GW)
Ideal for testing pipes over long distances, guided wave testing uses ultrasonic wave forms to reflect changes in the pipe wall, which are then sent to a computer for control and analysis. Guided wave testing can be carried out using medium or long range tests - guided wave medium range ultrasonic testing (GW MRUT) and guided wave long range ultrasonic testing (GW LRUT). GW MRUT techniques cover an area of 25mm to 3000mm, while GW LRUT covers distances greater than this and can be used to inspect areas over hundreds of metres from one location.
Advanced Ultrasonic Methods
Automated Inspection
The benefit of automation is achieved by the integration of NDT sensors with standard commercially available industrial robots as well as collaborative robots, also known as “cobots”. Custom written software for acquiring and visualising data creates a seamless and intuitive user experience that can be adapted to specific needs.
TWI has developed several highly capable automated inspection systems suited to both research and development work as well as production inspection.
Phased Array Ultrasonic Testing (PAUT)
PAUT probes are different from conventional UT probes in that they consist of an array of individual elements that can be pulsed independently. By controlling the times at which each element is fired, sound beams can be focussed or steered. By sweeping the beam through a range of angles or depths, cross-sectional views can be generated using one probe where several probe and wedge combinations may have been required with conventional UT. A virtual probe can be created from a number of elements and this can be electronically indexed along the length of the array to create a wide paintbrush scan.
Learn more
Full Matrix Capture (FMC)
FMC is an evolution of the PAUT technique and uses the same probes. Its main advantage is that there is no need to focus or steer the beam as the entire area of interest is in focus. It is also relatively tolerant of misaligned flaws and structural noise. This makes it very easy to set up and use. The disadvantage is that the file sizes are very large and the acquisition speed can be slower than with PAUT.
Learn more
Virtual Source Aperture (VSA)
VSA is a variation on FMC that retains most of the advantages of its superior image quality, but with greatly reduced file sizes and acquisition speeds that can exceed that of PAUT.
Vibration Analysis (VA)
This process uses sensors to measure the vibration signatures from rotating machinery in order to assess the condition of the equipment. The types of sensors used include displacement sensors, velocity sensors, and accelerometers.
Learn more
Visual Testing (VT)
Visual testing also known as visual inspection is one of the most common techniques which involves the operator looking at the test piece. This can be aided by the use of optical instruments such as magnifying glasses or computer-assisted systems (known as 'Remote Viewing').
This method allows for the detection of corrosion, misalignment, damage, cracks, and more. Visual testing is inherent in most other types of NDT as they will generally require an operator to look for defects.
Non-Destructive Testing Services
TWI has a wide range of industrial NDT services.
Find out which areas we can assist you in by visiting our non-destructive testing service pages below, or email us to find out how we can help:
What is the Difference Between Destructive and Non-Destructive Testing?
Destructive testing destroys or changes the part in some way such that even if it passes the test it is no longer fit for service. Examples might be tensile testing, 3 point bend test or macro sectioning. NDT does not destroy or change the part such that it is still fit for service if it passes the test.
What are the Advantages of using NDT?
There are a number of distinct advantages, the most obvious of which is that the pieces being tested are left undamaged by the process, allowing for an item to be repaired rather than replaced should any problems be found.
It is also a very safe testing method for operators, with most techniques being harmless to humans, although some types of test - such as radiographic testing - still need to be conducted under strict conditions. This testing technique can also help prevent injury or fatalities by ensuring structures, components and machinery is safe.
Digital Radiography - Non-Destructive Testing (NDT)
Non-destructive testing is also a very accurate way of inspection since the tests are repeatable and a number of tests can be used together to correlate results.
These testing methods are also economical. Unlike destructive testing, NDT is cost effective as it can prevent the need to replace an item before malfunction occurs without destroying the piece itself.
This testing technique also offers operators peace of mind, knowing that equipment is functioning as it should, preventing future accidents and determining any measures that can be taken for life extension.
It is also useful for testing of welds and verification of welding procedures to ensure that a welding process has been completed to the correct specification within the bounds of quality control, for example to make sure that the base metal has reached the correct temperature, cooled at the specific rate and that compatible materials have been used to prevent welding defects.
Where is Non-Destructive Testing used?
It is used in most industries, including aerospace, automotive, power, marine, and oil and gas.
Learn with TWI
Whether you are already working in NDT and wish to further your skillset or want to advance your career into this area, TWI offers training and certification as both off-the-peg and bespoke courses, including e-learning options.
Find out more about NDT training
Discover In-Demand NDT Jobs
Our exclusive Jobsite, powered by industry-leading expertise, offers curated NDT jobs from 550 reputable companies across multiple sectors. Begin your 7-day free trial now and elevate your professional journey.
See all our in-demand NDT jobs
Conclusion
Non-destructive testing is a valuable technique used by many industries to evaluate the properties of a material, component, structure or system without causing any damage. There are various types of NDT such as visual inspection, radiography, ultrasonic testing, magnetic particle testing and penetrant testing. Each type has its own advantages depending on the application.
Overall, NDT is a very versatile and useful technique that can help identify problems or defects in materials or structures without causing any damage.
For specialist advice:
