Laser Micromachining and Surface Modification Database
Project Code: 25286
  • Characterise the surface modification and micromachining of a wide range of materials using an ultrashort pulsed laser
  • Investigate the effects of picosecond laser pulses on key materials, with a view to transferring this knowledge to real parts and products in later project work
  • Development of a new project leader who will become the TWI specialist in this field in addition to the skills acquired during the EngD programme
  • Establish TWI as a knowledge centre for ultrashort pulsed laser processing of materials for surface modification and micro-structuring
Project Outline
The concept of this project is to develop a state-of-the-art ultrashort laser processing facility, and a design database of process parameters for key materials. This will provide a new research facility, which can be used to develop micromachining and surface modification processes, for a range of materials and applications.
Several materials deemed important for their respective industries will be selected and processing trials will be conducted, altering the wavelength, scanning speed, pulse repetition rate, average power and pulse energy. This will enable TWI members to access laser micromachining technology, accompanied by experimental data to help assess its viability for specific applications.
Current materials under consideration, together with their respective industry sectors are listed in Table 1.
Table 1 - Candidate materials for database inclusion, grouped by industry sector
Medical
Aerospace & automotive
Renewable energy/
photovoltaics
Oil & gas
Electronics
PEEK
Steels
Copper
PP
Silicon
Stainless steel
Aluminium,
Al alloys
Carbon/graphite
PU
OLED compounds
Nitinol
Magnesium alloys
Titanium dioxide
Steels
Glasses
Magnesium alloys
CFRP
Perovskite-based compounds
Fusion-bonded epoxy
Sapphire wafer
PLLA polymer
Metal matrix composites
Transparent conductive oxides (TCOs)
PE (including HDPE/LDPE)
Platinum
 Titanium
Gold
Titanium
Silver
Relevant Industry Sectors
Industry Need
Ultrashort laser processing potentially offers extensive advantages over other methods, such as longer-pulsed or continuous wave laser technology, in high value manufacturing industry. Using a single laser system, the following benefits can be achieved:
  • Limited thermal damage to components (negligible heat-affected zone)
  • Extremely precise (~10μm repeatability) marking for decorative or functional applications
  • Production of multifunctional complex parts (for example, intricate conductive tracks on a substrate)
  • Contactless machining at the micro/nano level
  • Surface modification, i.e. introduction of chemical changes to a surface as a preparative procedure to improve adhesion (improvements of the adhesion strength by a factor of at least 10 have been found for those polymers that have been laser treated) by modifying the friction co-efficient or altering the hydrophobicity/hydrophilicity
  • Applicable across a wide range of material types
  • Negligible consumables
  • Higher-throughput processing
By varying the process parameters (particularly power and energy density), the effect can range from surface cleaning to chemical surface modification and finally material ablation/removal. Parameters can also be fine-tuned to increase either hydrophobicity or hydrophilicity, depending on the specific conditions applied.
Most of these advantages are not currently offered by other laser processes. Examples of laser micromachining and surface modification applications are presented in the attached schematic.
