What are Wind Turbine Inspection Robots? Why Use Them?
Wind turbine inspection robots are robotic devices that are used by onshore and offshore wind turbine operators for the inspection and repair of their assets, most notably on the wind turbine blades themselves.
These robotics systems safely and cost-effectively check for blade damage using a variety of blade inspection techniques and technologies, including high definition cameras for visual inspections and ultrasonic sensors to detect defects occurring below the surface.
While these robots can be deployed with a range of technological capabilities, the cost and safety aspects are also significant drivers for the adoption of wind turbine inspection and repair robots by the wind power industry.
Wind turbines are often located in remote regions and exposed to extreme environments, especially when located offshore. Downtimes and repairs caused by the failure of both onshore and offshore renewable energy assets are costly and the safety implications of a failure are also considerable.
Subjected to hail, rain, humidity, high winds, lightning strikes and millions of load cycles during their lifetime, wind turbine blades often need to be inspected on location. However, manual inspection of a wind turbine blade is dangerous for inspectors using rope or aerial lift access, requires suitable conditions, and is expensive for operators.
Inspecting a vertically positioned blade in-situ has also posed challenges for the designers of inspection robots, leading to a range of designs from those that use a combination of suction and tank tracks to traverse the surface of a blade, to suction-cup legged inspect and repair robots.
TWI
TWI provides our Industrial Members with support for a range of services related to wind turbine inspection. This includes our work on the Horizon 2020-funded SheaRIOS project, the European DashWin project, the Innovate UK-funded RADBLAD (In-service X-ray Radiography of Offshore Wind Blades) project, and the Bladesave Project, among others. Our expertise in this area has been used to help manage the structural integrity of wind power assets as well as improving operating efficiencies and inspection methods.
TWI is an Industrial Membership based organisation who can provide your company with an extension to your own resources. Our experts are dedicated to helping industry improve safety, quality, efficiency and profitability through all aspects of materials, joining, and allied technologies. Industrial Membership of TWI currently extends to over 600 companies worldwide, embracing all industrial sectors.
Contact us today to find out more:
How They Work
Wind turbine blade inspection robots have a number of similarities with regards to the technology they use to overcome the challenges associated with their tasks.
Basically-speaking, all of the robots need to be able to maintain a steady grip on the blade to make sure that the images they attain are accurate, they also need to be remotely controllable and have a delivery system for getting them into position for the inspection.
Most inspection robots use some form of suction to adhere to the blades as they move across them, which also ensures they remain stable during the inspection.
Different inspection robots use different technologies for the actual inspection tasks – from high-precision video cameras for external, visual inspection to ultrasonic or infrared arrays that allow subsurface defects to be detected. Robotic inspection technologies can even include an ’electronic skin’ to “feel” the surface of a blade and collect data on the surface structure. Aside from inspection, these robots can also be used to carry out basic maintenance tasks, such as cleaning and resurfacing the blades.
As mentioned above, wind turbine inspection robots differ in design when it comes to how they are deployed and how they traverse the blades but, before we go into this in more detail, we need to mention the use of drones…
Drones
Drones have also been investigated as a solution for inspecting wind turbines. They are already used to inspect other large structures that are difficult or dangerous for humans to inspect, such as bridges, monuments and towers.
These drones use high resolution cameras and infrared sensors to detect heat signatures in the blades. As the sunlight diffuses through the blade, the difference in thermal properties demonstrate where subsurface damage has occurred.
However, for more accurate inspection, suction-based inspection robots are still preferred so, while a drone may be able to detect a potential defect, a crawling robot may still need to be deployed.
Drones have also been used to deliver inspection robots to wind turbine structures.
Deployment and Design
It is one thing to test a robot on a demonstration turbine blade in laboratory conditions, but these inspection robots need to be able to cope with extreme environments when deployed on a wind turbine in service.
The methods used to deploy and move the robot across the blade differ between different designs, but generally either use a legged crawling design or a tracked or wheeled design.
BladeBUG, for example, is a six-legged robot invented by entrepreneur Chris Cieslak. The robot uses suction cups on its feet to attach itself to wind turbine blades. These cups can change shape as the crawler moves along the blade, with a camera allowing the operator to see what is happening as they control it with a gaming controller. These robots can also be deployed at offshore wind farms using drones.
The International Climbing Machine, by contrast, is a remote controlled tank-like robot that can withstand high winds and successfully navigate over bolts and other obstacles. It uses an on-board vacuum suction system to create a seal as the caterpillar tracks drive it along the surface of the structure.
The Innovate UK-funded MIMRee (Multi-Platform Inspection, Maintenance and Repair in Extreme Environments) project is an example of various technologies coming together to aid wind turbine inspection. This project used an unmanned vessel, drone and crawling robot to create a complete system for transporting, deploying and retrieving a blade crawling robot as well as carrying out visual inspection via drone. Once the drone has been used for a preliminary inspection it can return to the unmanned vessel to pick up the crawling robot and place it on the turbine blade for a closer inspection such as high-resolution imaging and non-destructive sensing, including ultrasound.
Advantages
Robots provide a number of advantages for wind turbine blade inspection, including being able to offer a safer, close-up inspection compared to humans and can also carry and use a range of inspection tools including cameras, sensors and artificial intelligence.
In addition, robots with scanners are able to find damage that cannot be seen with visual inspection by a human access team, locating smaller defects inside the blade, before they break to the surface.
Robots can also be deployed in conditions that would be unsuitable for humans to scale a wind turbine structure, while the turbines do not need to be shut down for maintenance when a robot is used.
Aside from the cost and the energy loss associated with shutting down a turbine, there is also a need to pay for crew transport vessels when using human inspectors. To offer some perspective, it is estimated that the MIMRee robotic system outlined above could save an average wind farm £26m over the course of its lifetime.
Robotic inspection offers detailed images of a structure, which are often superior to those attained by high-powered telescopes that can be hindered by poor light, cloud cover or precipitation.
As well as inspection, these robots can be used for other additional tasks, such as smoothing out the blade’s material and applying protective surface coatings.
Conclusion
Robots are changing routine maintenance procedures for wind turbines, leading to fewer dangerous ascents for human inspection teams and offering a cost-effective method of checking for surface and subsurface problems.
The move towards greater automation in wind turbine inspection follows the trend across industry to use robots for work that is dull, dirty or dangerous, improving safety, preventing costly performance problems, and reducing operating costs at the same time.
