Pros and Cons of Robotic Welding
Welding techniques encompass various methods, including robotic welding, which involves the utilisation of mechanised programmable tools to fuse materials by heating, blending, and subsequently cooling them.
Welding robots, or robotic welding, stand as a significant innovation for manufacturers, allowing them to address the requirements of welding processes effectively. Numerous manufacturing firms employ robotic welding systems to enhance productivity and meet competitive market demands efficiently. Each welding technique, be it manual or robotic, carries its pros and cons.
Contents
TWI
TWI provides support to our Industrial Members for a range of engineering challenges across different industries, including research and technology and engineering consultancy, as well as offering training services and professional development and support for engineers with The Welding Institute.
Pros of Robotic Welding
There are four basic advantages to automated welding:
  • Enhanced Weld Quality: Through electronic weld process controllers, the automated welding process enables operators to uphold weld integrity consistently. Moreover, automated welding guarantees high repeatability, as robots adhere to the same precise process each time, ensuring more consistent results.
  • Increased Output: Robots exhibit natural speed superiority over humans without compromising accuracy, operating without fatigue or the need for breaks.
  • Reduced Scrap: Robot-controlled welding achieves a remarkable level of accuracy and efficiency, leading to a decrease in scrap production as compared to manual welding.
  • Lower Labour Costs: Even in semi-automatic welding setups, a reduced number of human workers translates to diminished labour expenses.
Moreover, automated welding machines operate various welding processes continuously, minimising the need for additional staffing in production. This eliminates considerations for labour-related costs such as injuries, sick leave, staff turnover, and overtime.
  • Higher Initial Investment: Despite its numerous advantages, incorporating robotic welders demands a greater upfront expense compared to manual welders. The installation cost of an automated system can vary significantly; however, there are more economical alternatives like reconditioned robots available.
  • Infeasibility for Small-Scale Projects: Smaller projects are more suited for manual welders due to their ease, cost-effectiveness, and reduced stress. Robotic welding is pivotal for large or long-term projects. Implementing robotic automation into smaller projects might extend the programming time longer than the actual welding process, proving counterproductive.
  • Reduced Flexibility: Lack of adaptability can pose challenges. Unlike humans, robots lack innate instincts to respond intuitively. While technology advancements may change this, currently, a robot's capacity to assess and react to situations is limited. Consequently, operators need to halt the robotic process and reprogram a new process, leading to interruptions.
  • Initial Investment: While automated welding reduces labour expenses in the long run, the initial costs for the machinery are often substantial.
  • Maintenance Costs: Apart from the initial expense, ongoing machinery maintenance costs need to be considered.
  • Technical Challenges: Like any technology, automated welding machinery may encounter technical issues, potentially causing significant downtime for companies reliant on robotic welding.
  • Limited Versatility: Robotic welding machines excel at repetitive tasks but may require reconfiguration for diverse manufacturing needs, incurring time and potential expenses.
Side by Side Comparison
Here is a side-by-side comparison of the Disadvantages and advantages of robotic welding:
Higher efficiency: Robots can work continuously without taking breaks or getting tired, leading to faster and more efficient welding. This can result in increased productivity and cost savings for businesses.
Higher start-up costs: Robotic welding necessitates the acquisition of robots and the training of robot operators. The cost of doing so may be too high since the welding jobs you may be having are few. Hence, outsourcing for the robotic welding service could be the most ideal cost-saving act.
Higher consistency: Robots can perform the same welding task repeatedly with the same level of accuracy, leading to consistent results. This can lead to higher quality welds and fewer defects.
Less flexibility: Robots are not as flexible as humans and may not be able to handle different weld types. This can limit the range of welding tasks that can be performed by robots.
Safer: Robots can be programmed to work in hazardous environments or areas that are difficult for human welders to access. This leads to increased safety for workers and a reduction in workplace accidents.
Inability to make decisions: Robots are not able to make decisions about certain procedures if necessary data is missing.
Higher quality: Robotic welding produces high-quality welds with minimal defects. This can lead to better product quality and a reduction in the number of rejected products.
Not suitable for smaller projects: For smaller projects, it may be easier, cheaper, and far less stressful for a manual welder to undertake jobs. Incorporating robotic automation processes into smaller projects could mean that the programming time actually takes longer than the welding job itself, and this would be counterproductive.
Increased output: Robots can work faster than humans, without any loss of accuracy, and they do not fatigue or need to take breaks. This allows for greater throughput and productivity.
Limited functions: The functions of robots can be limited, especially if you are using specialised robotics for processes such as welding. The designated process may be efficient, but some robots are unable to perform certain processes, making them inefficient.
It is important to note that, while robotic welding has many advantages, skilled welders are still essential in the welding industry, and robots can work alongside them to enhance productivity and quality. For detailed work or complex welds, especially those that are not in straight lines or at right angles, a person is likely to complete these welds better.
Conclusion
In summary, robotic welding stands as a ground-breaking innovation revolutionising manufacturing by offering unparalleled efficiency and productivity, particularly in large-scale projects. Its advantages include superior weld quality, increased output, reduced scrap, and lowered labour costs. However, the initial high investment, limitations in adaptability for smaller projects, reduced flexibility, ongoing maintenance expenses, technical challenges, and limited versatility pose significant considerations.
Despite the limitations, skilled welders remain essential for intricate or specialised tasks, possessing adaptability and expertise that robots currently lack. The optimal strategy lies in harmonising the strengths of robotic welding and skilled human labour. Robots excel in repetitive tasks and consistency, while human welders contribute expertise for complex welds and adaptability to unique needs. Collaborative efforts between robotic technology and human skill ensure a balanced approach, maximising efficiency, quality, and adaptability in welding processes.
