ISO 15614-1: 2004+A2:2012
ISO 15614-1:2017
Reason for change and main consequences
8.2 Manufacturer
Qualification valid for other workshops under the same technical and quality control
Technical and quality control not mentioned. Qualification valid “in workshops or sites when the manufacturer who performed the welding procedure test retains complete responsibility for all welding”
- The new wording clarifies that a company can apply another company’s WPQR, provided that the companies that qualified the WPQR retains complete responsibility for all welding
- For example: Company A, who carried out the procedure qualification, can pass the WPQR to Company B, provided that Company A retains complete responsibility for all welding
- Company A would take a significant risk, as it would be responsible for welding carried out by a different company.
8.3.1 Parent material grouping
Refers to CR ISO 15608
- Refers to ISO/TR 15608.
- Where materials are assigned to groups by ISO/TR 20172, ISO/TR 20173 or ISO/TR 20174, those assignments shall be used.
- Separate qualifications required for materials not covered by standards above
- Rules to assign parent material grouping made clearer
- ISO/TR 20172, ISO/TR 20173 or ISO/TR 20174 are very useful documents to assign groups to EN, American and Japanese materials
Table 5 Range of qualification for steel groups and subgroups
Table 3 has very few dissimilar combinations
Table 5 is much more comprehensive
Table 5 is now easier to use, especially for dissimilar metal welds
For Group 11 (mainly ASTM/ASME materials), note b applies, ie steels in the same sub-group and any lower sub-group within the same group lower sub-groups are qualified
For Group 11, note a applies, ie equal or lower specified minimum yield strength steels (independent of the material thickness) are qualified
- Group 11 covers ASTM/ASME carbon steels, for which the specified maximum carbon content (up to 0.30%) is typically greater than for ‘EN or ISO steels’
- Group 11 steels represent a worse case in terms of weldability (potentially higher carbon), compared to EN or ISO steels with the same or lower specified yield strength
- The previous standard was considered unnecessarily restrictive, as Group 11 materials only qualified Group 11
- Group 11 material now cover Group 1 with the same or lower specified minimum yield strength
Table 6 Range of qualification for nickel alloys groups and subgroups
Table 4 has very few dissimilar combinations
- Table 6 is much more comprehensive
- Dissimilar combinations for groups 8-4X and 11-4X introduced
Table 6 is now easier to use, especially for dissimilar metal welds
Table 7 Material and weld deposit thickness (butt welds)
Table 5 has the same ranges for weld deposit thickness material thickness
- Separate qualification ranges for levels 1 and 2
Table 7 essentially similar to previous Table 5, except:
- Deposited weld metal thickness (s) and material thickness (t) treated separately
- Ranges for thickness of test piece have changed
- No minimum thickness for deposit thickness
- 0.5t – 2t for material thickness < 3
- When s(test) > 20, new rules for s(max)
- t(test) ranges 20-40, 40-100, 100-150, >150mm
- S(max) = 1.33s(test) if t ≥ 150
- Weld metal thickness and material thickness are treated separately to improve clarity
- Users should be aware of the new thickness of test piece ranges and the new qualification ranges.
Table 8 Material and throat thickness for fillet welds
Table 6:
- 3<t<30mm range = 0.5t(3 min) – 2t
- t ≥ 30 : single run throat – no range (each throat depth to be qualified separately)
Table 8 :
- 3<t<30mm range = 3-2t
- Single run throat – range is 0.75a – 1.5a
- As 3mm is the minimum material thickness then changed from 0.5t(3 min) – 2t to 3-2t
- The standard committee considered that there should be a range of qualification for the throat thickness and not restricted, as previously, to the throat thickness used in the test piece.
Table 9 Pipe and branch connections diameter
Table 7 :
- For D ≤ 25 range is 0.5D – 2D
- For D > 25 range is ≥ 0.5D (25 min)
Range is ≥ 0.5D for all diameters
- The committee considered the previous ranges to be too restrictive, so a range of ≥ 0.5D for all diameters was agreed.
8.4.1 Welding processes
For multi-run welds, no requirement to test weld metal deposited from each welding process
- When the test piece is welded with more than one welding process;
- The procedure is valid only for the sequence of processes used on the test piece.
- Test specimens shall include deposited material from each welding process used.
- Addition: “back run is permitted using one of the welding processes used in the qualification.”
- For multi-process welds, the test specimen must now include deposited metal from each welding process. This was not explicitly required in the previous edition.
- For multi-process qualification (eg TIG+MMA), either of the processes can be used to deposit a backing run
8.4.2 Welding positions
8.4.2
The wording has been revised, the principles are the same apart from;
- two test pieces are required except in the case of when a fixed pipe is used for the qualification.
- More examples of high and low heat input positions provided in a NOTE
- There has been much discussion on the clause and the wording was revised to make it clearer. The principles are largely the same but;
- In case of fixed pipe, it is not necessary to weld two test pieces since, for example, the hardness can be taken from the overhead position (PE) and the impact from the horizontal (PC) position - see Fig 6
- The UK specifically asked for the following to be included 'Vertical down welding (welding positions PG, PJ and J-L045) shall be qualified by a specific test' which was agreed.
- The Note was added to help the user to understand which are the highest and lowest heat input positions.
- The use of ‘and’ in the note, for example ‘PF and PA’ for high heat input position, may be misleading. Users may believe that two test pieces, one in PA and one in PF position, are required to test the high heat input. The intent of this note is that only one position per heat input level is required.
- IMPORTANT: notes are included in standards to give examples and help the users. A note cannot include requirements. The positions specified in the note are for example only. The user may apply positions other than those indicated in the note.
8.4.3 Type of weld / joint
8.4.3
New clauses:
- Weld made from both sides qualifies welds made from one side with backing
- Build-up qualified by butt weld
- Buttering shall be performed by a separate test piece in combination with the butt weld (to allow mechanical testing).
Modified clause (new text in Italic):
- When impact or hardness requirements apply, it is not permitted to change a multi-run deposit into a single run deposit (or single run on each side) or vice versa for a given process
- (i) and (k) were agreed by the committee and cover conditions that were not explicitly addressed in the previous edition
- (j): a change from single to multi-run, and vice-versa, is expected to affect hardness and toughness in the HAZ and weld metal. If hardness and toughness are not to be tested, this change should not apply.
- (h) is not permitted when thermal gouging (arc air, plasma) is used to remove the weld root, because this is a thermal process and it affects the mechanical properties of the joint.
8.4.4 Filler materials
- Covered by separate clauses 8.4.4 (designation) and 8.4.5 (make)
- 8.4.5: filler metals restricted to the specific make for ‘fluxed’ processes 111 (MMA), 114 (self-shielded), 12 (SAW), 136 (FCAW inter gas) and 132 (FCAW active gas)
- Covered by one clause (8.4.4)
- Process 137 is replaced by process 132
- Restrictions on filler metals for ‘fluxed’ processes (manual metal arc, SAW, FCAW) if impact testing is required at temperatures less than ‑20°C
- Process 137 has been replaced by process 132 in the latest version of ISO 4063
- The requirement for testing at -20°C is only mandatory if required by the Application Standard
8.4.7 Heat input (arc energy)
8.4.8:
- heat input only to be recorded
- ±25% qualified range, depending on testing requirements
- Heat input calculation according to EN 1011-1
8.4.7:
- User can use either heat input or arc energy for welding control, to be calculated in accordance with ISO/TR 18491
- the calculation (either heat input or arc energy) shall be documented
- ±25% qualified range stays the same (+25% when there impact requirements apply and -25% when hardness requirements apply)
- For tack welding heat input need not be verified but adjustable parameters (amps/volts) should be checked
- Reference to ISO/TR 18491 to take modern power sources into account
- The traditional formula for heat input/arc energy in EN 1011-1 is inadequate when pulsed welding (eg P-GTAW or p-GMAW) or power sources with complex waveforms are used (eg Lincoln STT, Fronius CMT, ESAB Superpulse, Kemppi WISEROOT etc)
- Using the traditional formula and average values for A and V has been proven to be inaccurate. Also, average A and V cannot be readily determined, when a complex waveform is applied.
- ISO/TR User can report heat input or arc energy, to be calculated according to ISO/TR 18491
- provides separate rules to calculate heat input/arc energy for waveform controlled and non-waveform controlled processes
- These are identical to the rules introduced in ASME IX since 2010
- User should familiarise with ISO/TR 18491
8.4.8 Preheat temperature
8.4.9: The minimum qualified preheat temperature is that recorded in the test (applied at the start of the test)
- The preheat temperature can be reduced by no more than 50°C from the recorded preheat temperature on the WPQR otherwise requalification is required
- A decrease in the preheat temperature is only permitted if ISO/TR 17671-1 2 is satisfied
- Preheat temperature reduction similar to ASME IX, which permits a 55°C reduction .
- A reduction of 50°C is permitted, rather than 55°C, to prevent level from being less stringent than ASME IX
- It is permissible to reduce the preheat temperature from the recorded preheat temperature on the WPQR but by no more than 50°C and only if ISO/TR 17671-2 is satisfied
- This does not mean that preheat should be reduced for production welding. ISO/TR 17671-2 should be applied to determine the required level of preheat for production welding.
- Also, a decrease in preheat temperature may not be permitted by the applicable construction code, if any.
8.4.9 Interpass temperature
8.4.10: Upper limit for the interpass temperature (IP) is that recorded in test.
- An increase in the maximum interpass temperature of more than 50°C shall require re-qualification
- For Groups 8, 10, 41-48, there is no change, as the maximum interpass temperature (IP) is that recorded in the welding procedure test.
- IP temperature increase similar to ASME IX, which permits a 55°C increase .
- An increase of 50°C is permitted, rather than 55°C, to prevent level 2 from being less stringent than ASME IX
- Increase not permitted for austenitic materials (groups 8, 41-48) and duplex stainless steels (group 10), as this may adversely affect properties such as toughness, phase balance and corrosion resistance
8.4.11 Heat treatment
8.4.12: PWHT temperature range validated is the holding temperature recorded in the test ± 20°C
- No changes from previous standard regarding temperature range validated and heating rates etc.
- Introduction of four PWHT conditions which will require a separate procedure qualification
- For material groups 1-7, 9-11 the following conditions apply:
- Stress relief (below lower transformation temperature), - normalizing (above upper transformation temperature), - normalising followed by Q&T, - PWHT between lower and upper transformation temperatures.
- PWHT temperature range validated is still the holding temperature recorded in the test ± 20°C
- For all other groups PWHT shall be ‘within a specified temperature range’.
- Introduction of four groups of PWHT in line with ASME IX (see QW-407.1)
- Major change is the introduction of four types of PWHT for ISO/TR 15608 material groups 1-7, 9-11
8.5.1 Submerged arc welding
8.5.1:
- 8.5.1.1 Each process variant shall be qualified independently
- 8.5.1.2 Range is limited to ‘make and designation’ of the flux
- 8.5.1(a) Each process 12 variant (121 to 126) shall be qualified independently. The introduction of process variant such as multi-wire, addition of hot or cold wire, etc will require requalification
- 8.5.1(b) Range is limited to the ‘manufacturer, trade name and designation of the flux’
- 8.5.1(c) New clause added to cover the use of re-crushed slag
- Clause revised to improve clarity and address some frequently asked questions from users (eg on multi-wire, hot/cold wire etc)
- Clause on re-crushed slag added in line with ASME IX (QW-404.36)
- Limiting the range of qualification to the Trade Name used in the test is an additional restriction.
- It should be noted, when using re-crushed slag a new batch or blend of crushed slag requires a new qualification test.
8.5.2.1 Gas-shielded metal arc welding (Shielding gases)
8.5.2: Increase of 10% of CO2 content permitted for shielding gas
Maximum permissible deviation for the CO2 content has now been clarified as a ‘relative deviation’ of ±20% of CO2 from nominal composition
- The previous wording (shall not exceed 10%) was unclear and numerous enquiries were being submitted
- For example, if an increase of 10% is permitted, does a gas mixture 80% Ar 20% CO2 cover:
- Up to 22% CO2, calculated as [20 + (10% of 20)]
or
- Up to 30% CO2, calculated as (20%+10%)
- According to ISO 15614-1:2017, for the example above, ‘relative deviation of ±20%’ means that a gas mixture 80% Ar 20% CO2 covers:
- Minimum 16% CO2, calculated as [20 - (20% of 20)]
- Maximum 24% CO2, calculated as [20 + (20% of 20)]
8.5.2.3 Gas-shielded metal arc welding (Transfer mode)
Spray or globular transfer modes qualify spray and globular
New clause on Transfer Mode
- 8.5.2.3.1 The range of qualification for the various transfer modes including the pulsed mode eg qualification using spray, pulsed or globular qualifies spray, pulsed and globular
Range of qualification now covers the pulsed transfer mode and the newer waveform-controlled power sources
No reference to waveform controlled welding
New clauses on waveform controlled welding:
- 8.5.2.3.2 Waveform-controlled welding: the power source manufacturer and waveform control mode are essential variables
- 8.5.2.3.2 Welding with pulsed mode and without waveform-control: the power source manufacturer and other pertinent information shall be recorded, but a change does not require requalification
- 8.5.2.3.2 Non waveform-control welding: the power source manufacturer shall be recorded, but a change does not require requalification
In practice:
- If a power source with a complex waveform is used (eg Lincoln STT, Fronius CMT, ESAB Superpulse, Kemppi WISEROOT, EWM forceArc etc), the power source manufacturer and the waveform mode must be recorded in the WPQR and cannot be changed. For example, a qualification with Lincoln STT only covers Lincoln STT.
- If ‘conventional’ pulsed welding is applied (no complex waveform), the power source manufacturer and the pulse parameters must be recorded in the WPQR. The power source manufacturer can be changed without requalification. NOTE: all other variables must be within the qualified range. So, one can change the power source BUT the pulsing parameters must be such that the qualified heat input limits are not exceeded.
- For ‘standard’ welding (no complex waveform or pulsing): the power source manufacturer shall be recorded in the WPQR, but it can be changed without requalification.
8.5.3.1 TIG welding, shielding gases
8.5.3: Shielding gas mixture limited to symbol of the gas or nominal composition
- Shielding gas mixture limited to the nominal composition or symbol of the gas.
- A relative deviation of max ±10% from the nominal He content is permitted
See 8.5.2.1 for explanation of ‘relative deviation’
8.5.4 Plasma arc welding
8.5.4: No reference to joint type
A change in the type of joint preparation (groove) requires a re-qualification.
Clause on joint type added in line with ASME IX (QW-257 and QW-402.1)
8.5.6 Backing gas, all processes
8.5.3:
- Backing gas rules apply to process 14 only
- 8.5.3.2 A weld procedure test made without a backing gas qualifies a welding procedure with backing gas.
New clause on Backing Gases which covers the Material Groups
- Backing gas rules apply to all processes
- No backing gas qualifies backing with I and N1-N3 to ISO 14175 (not vice versa)
- Main group to ISO 14175 covers all sub-groups within the same group
- Material groups 1-6 – Gas groups I and N1, N2, N3 are interchangeable
- Material groups 7 and 10 – Any change in backing gas classification requires requalification
- Material groups 8, 41-48 – Gas groups I, N, R are interchangeable
- Backing gas can be omitted when ≥5mm thick material backing is used
The rules on backing gas have been improved following feedback from users
Annex A
Not present
New Annex but not relevant for Level 2
