Frequently Asked Questions
The important parameters for hot plate welding are:
- the dwell/changeover time
- the temperature of the hot plate
- the heat soak time
- the welding pressure
- the heat soak pressure
- the welding time
- the joining displacement
- the cooling time
Recommended welding conditions vary depending on the material to be welded, and the wall thickness of the components.
Preparation for hot plate welding is also important. The parts to be joined must be flat and square to the heating tool. This is to avoid uneven heating of the component.
See further information about polymer welding or please contact us.
