Surface energy values usually have the units of mJ/m 2. Some sources quote the critical surface tension in units of mN/m, which is equivalent to surface energy. The surface energy values of some typical materials are shown in the two tables. The first table shows values for low and high surface energy solid materials, whilst the second table shows values for the liquids used in contact angle measurements that are used to determine surface energies.
There are various methods for obtaining surface energy values and there can be some variation in the values determined, dependent on the method used. This variation reflects the genuine difficulties that exist in performing these types of measurement, and this topic is still an area of active research as greater levels of understanding are sought.
Table of surface energy values of solid materials
Material type | Surface energy (mJ/m 2), γS (Experimental, estimate * or theoretical † .) |
Low energy surfaces - plastics, rubber and composites |
Polyhexafluoropropylene Polytetrafluoroetylene - PTFE Poly(vinylidene fluoride) - PVF Poly(chlorotrifluoroethylene) Polyethylene - PE Polypropylene - PP Poly(methylmethacrylate) - PMMA Polystyrene - PS Polyamide - PA, Nylon-6,6 Poly(vinylchloride) - PVC Poly(vinylidene chloride) Poly(ethylene terephthalate) Epoxy - typical rubber toughened Epoxy - typical amine-cured Phenol-resorcinol resin Urea-formaldehyde resin Styrene-butadiene rubber Acrylonitrile-butadiene rubber Carbon fibre reinforced plastic (CFRP) abraded |
12.4 19.1 30.3 33.5 32.4 33 (*) 40.2 40.6 41.4 41.5 45.0 45.1 45.5 46.2 52 (*) 61 (*) 29.1 36.0 58.0 |
High energy surfaces - metals, oxides and ceramics |
Aluminium oxide (Al 2O 3) - anodised Aluminium oxide (Al 2O 3) - sapphire Berylium oxide (BeO) Copper Graphite Iron oxide (Fe 2O 3) Lead Mercury Mica Nickel Platinum Silicon dioxide - silica Silver |
169 638 1107 ( † ) 1360 ( † ) 1250 ( † ) 1357 ( † ) 442 ( † ) 319 ( † ) 120 1770 ( † ) 2672 287 890 ( † ) |
Source of information: 'Adhesion & Adhesives - Science & Technology', A J Kinloch, Chapman & Hall, London, 1987.
Table of surface energy values of liquids used for surface energy measurements
Liquid | Surface energy (mJ/m 2) γLV |
Hexane Octane Decane Dedecane Tetradecane Hexadecane 2-Ethoxyethanol Polyglycol 15-200 Polyglycol E-200 Dimethylformamide Pyridine Tricresylphosphate Dimethylsulphoxie 1-Bromonaphthalene Ethan-1,2-diol Di-iodomethane Formamide Glycerol Water |
18.4 21.8 23.9 25.4 26.7 27.6 28.6 36.6 43.5 37.3 38.0 40.7 43.6 44.6 48.3 50.8 58.3 64.0 72.2 |
Further information
For assistance with this technology please contact us.
