Is it possible to weld dissimilar plastics?
Frequently Asked Questions
As a general rule, dissimilar plastics cannot be welded successfully, but there are a few exceptions to this rule. A typical example is a car rear light cluster. The PMMA (polymethylmethacrylate) lens can be hot plate welded to the ABS (acrylonitrile butadiene styrene) housing. It is possible to weld PMMA to ABS because they are both amorphous and possess similar Tg (glass transition temperature) values; Tg for PMMA is 85-105°C, Tg for ABS is 110-125°C.
Other combinations of dissimilar plastics that can be welded are PS (polystyrene) to ABS, and PMMA to PC (polycarbonate). The table below provides a summary of other potential dissimilar combinations
See further information about plastics welding and testing or please contact us.
  Not weldable
x Weldable
- Some grades weldable
? Some reports of successful welding
Other polymers do not form dissimilar welds.
  ABSABS/PCAcrylicModified PPOPA 12PBTPCPEPEIPETPolysulphonePP
Acrylonitrile butadiene styrene ABS x x x ?   ? x   ?
Acrylonitrile butadiene styrene/polycarbonate blend ABS/PC x x -       x
Polymethylmethacrylate Acrylic x - x       -
Noryl Modified PPO ?     x     ?
Nylon 12 PA 12         x   ?
Polybutylene terephthalate PBT ?         x ?   ?
Polycarbonate PC x x - ? ? ? x   - ? -
Polyethylene PE               x       ?
Polyetherimide PEI ?         ? -   x
Polyethylene terephthalate PET             ?     x
Polysulphone Polysulphone             -       x
Polypropylene PP               ?       x
Polyphenylene oxide PPO       x
Polystyrene PS -   - x     -
Polyvinylchloride PVC -   ?     ?
Styrene acrylonitrile SAN - - - -
Styrene block copolymer SBC               ?
Styrene-butadiene-styrene SBS -   x
  PPOPSPVCSANSBCSBS
Acrylonitrile butadiene styrene ABS   - - -   -
Acrylonitrile butadiene styrene/polycarbonate blend ABS/PC       -
Polymethylmethacrylate Acrylic   - ? -   x
Noryl Modified PPO x x   -
Nylon 12 PA 12
Polycarbonate PC   -
Polyethylene PE         ?
Polyetherimide PEI
Polypropylene PP
Polystyrene PS   x   -   -
Polyvinylchloride PVC     x
Styrene acrylonitrile SAN   -   x   -
Styrene block copolymer SBC         x
Styrene-butadiene-styrene SBS   -   -   x
Sources
  1. Reinhold Martin, 'The Use of Lasers with Technical Polymers', AILU Conference, 'Laser Processing of Polymer-Based Materials', February 2004
  2. Grewell, Benatar & Park, 'Ultrasonic Welding' in Plastics & Composites Welding Handbook, Hanser 2003, ISBN 3-466-19534-3
  3. Benatar, 'Implant Induction (Electromagnetic) Welding' in Plastics & Composites Welding Handbook, Hanser 2003, ISBN 3-466-19534-3
  4. Froment, 'Linear & Orbital Vibration Welding' in Plastics & Composites Welding Handbook, Hanser 2003, ISBN 3-466-19534-3
  5. Watson, Rivett & Johnson ' Plastics - an Industrial & Literature Survey of Joining Techniques', The Welding Institute Research Report 301/1986
