In December 1965 a large pressure vessel being manufactured by John Thompson (Wolverhampton) Limited for the ICI Immingham plant fractured during a hydraulic test.
Damage to the vessel was extensive with four large pieces being thrown from the vessel. One of these, weighing approximately 2 tonnes, went through the workshop wall and landed some 46m away. One minor casualty was reported.
The vessel consisted of a plain shell of 1.7m inside diameter made from cylindrical strakes of 150mm thick silicon killed Mn-Cr-Mo-V steel. The end closures were forged, one end being a flange with a flat cover. The forging material was similar to the shell steel, however, a higher carbon content of 0.2% was used in the flange forging in order to meet the strength requirements in the thickest section. The forgings were supplied in a normalised and tempered condition. The overall length of the vessel was 18.2m and it weighed 167 tonnes. It had been destined for use as an ammonia converter with a design pressure of 35N/mm2 at 120°C.
The proof test requirement was for 48N/mm2 gauge pressure at ambient temperature (not less than 7°C) but the testing of the vessel was troubled by leaks from the bolted flange joint and several re-pressurisations were required. At the first attainment of 34N/mm2 pressure, the vessel failed accompanied by 'a kind of dull thud'. No one present noticed anything unusual before the failure. The ambient and water temperatures at the time were determined to be less than10°C.
The failure occurred at the flange end of the vessel. The flange forging was cracked through in two locations, the first two shell strakes broke into several pieces and cracking extended into the third strake.
