Innovative seam tracking for adaptive control during laser welding
TWI is working with PERMANOVA Lasersystem AB, BIT ADDICT and GKN Aerospace Engine Systems, Sweden, in the EC Framework 7 supported ‘LASHARE’ initiative, to develop and test a new seam monitoring and tracking system. This system is being developed to also be capable of process monitoring and fault recognition, with the goal of reducing the post-weld inspection burden for laser welded structures in the aerospace industry.
Project background
Laser welding can offer significant advantages when manufacturing high value, safety critical applications - offering a low distortion and high performance means of joining.
Nevertheless, narrow process tolerances can make it a challenge to maintain weld quality. Failure to monitor and control part preparation and cleanliness, part placement and seam fit-up, and the parameters of the process itself can all result in weld defects.
The InnoSeam project is addressing this challenge by developing a system capable of real-time seam detection, inspection and tracking, multi-sensor process monitoring and, based on observed changes in those sensor signals, the automatic alerting of possible set-up, equipment or welding faults.
The project uses a new version of Permanova’s existing seam finding, inspection and tracking system, combined with in-built LED coaxial illumination and imaging of the seam and the welding zone, along with plug-and-play compatibility with sensor-embedded delivery fibres (e.g. as available from Coherent (Optoskand AB)) for additional process monitoring.
Specifically, TWI role’s in this project is to build-up knowhow in the operation and capabilities of this system, and to identify its fault-detection functions, before then assisting in the validating of this performance at GKN, and confirming its use in reducing the reliance on expensive and time-consuming offline NDT.
Work programme
PERMANOVA, supported in software development by BIT ADDICT, has developed a laser welding head with in-built high intensity green LED seam/process zone illumination. A coaxially attached CMOS camera with a matching narrow bandpass filter is then used to obtain a view of the seam either prior to or during welding, for inspection and tracking purposes.
This same camera is also capable of viewing and recording (currently to 100 fps) a coaxial image of the interaction point between the incident laser beam and the materials being welded. For additional assurance, the head itself also monitors and records the temperatures of key optical components, as well as the health (scattered light and temperature) of the cover slide.
TWI is in the process of designing and executing an iterative series of welding trials using this equipment on materials and material thicknesses of industrial relevance to GKN, to ascertain the performance of this system and guide its further development.
A further development is that the system is also capable of communicating with, and recording data from (at a rate of up to 1000Hz), a sensor-enabled fibre. Using an appropriate fibre, signals such as the amount of back-scattered laser radiation and optical emissions from the process zone can also be monitored during welding.
With appropriate system training, post-weld video playback and sensor signal evaluations can then be used for weld quality and/or fault determination. Signal- and image-analysis routines also provide the means for real-time fault diagnosis.
These analyses indicate that the InnoSeam system will be capable of detecting a number of possible problems and faults during laser welding, including:
  • Incorrect seam position.
  • Poor joint fit-up.
  • Cover slide contamination.
  • Incorrect beam power being used during welding.
  • Changes between partial and full penetration.
  • Incorrect focus being used during welding.
  • Inadequate gas shielding.
Examples of aerospace structures from GKN Aerospace, whose manufacture involves laser welding
InnoSeam head a) coaxial illumination OFF b) coaxial illumination ON
InnoSeam HMI (top), welding head during use (bottom left) and an example of real-time process zone imaging (bottom right)
Examples of back-scattered (top) and optical radiations (bottom) monitored during the making of a test weld comprising three deliberate step changes in laser beam power
This work is in the process of developing and validating the performance of a new means of both seam and process monitoring and fault diagnosis, with first-to-market use foreseen at GKN Aerospace. This will, in turn, help GKN lighten the burden of post-weld NDT, bringing overall improvements in productivity and cost reduction.
For more information, please contact us.
Avatar Chris Allen Consultant
Dr Chris Allen is a Consultant in the Laser and Sheet Processes Section at TWI Ltd, and has over twenty years' experience as a welding engineer. He has an MA from Cambridge in Materials, and a PhD from Oxford, carried out in conjunction with Alcan. Following a short stint in academia, Chris has been in a technical project role since 2000, firstly at Corus, and then at TWI. Chris has developed, managed and delivered R&D projects, principally in laser processing, for clients in the aerospace, road transport, powergen, defence and shipbuilding industries, with clients including Rolls-Royce, GKN Aerospace, Saab Aerospace, Leonardo MW, ESA, Honda, Honeywell, JCB, Nippon Sharyo, UKAEA, Lockheed Martin, MBDA, Technip, Saipem, and the MoD/DSTL, as well as the European Commission and InnovateUK.
