Image Analysis for Control of Arc Welding Penetration
Control of automated welding often involves user input to account for in-process variations, such as changes in material thickness, misalignment of joints or inconsistencies in wire feed. These can alter the penetration of the weld joint and affect the resultant weld quality. This requirement for manual control and adjustment is why welding is often considered an "artisan" process, with the skills needed to perform this effectively being developed over a long period of time.
There are two potential solutions to this requirement. The first is to develop a welding procedure which has a very wide tolerance to changes in process variables, such as by introducing oscillation, and minimising those changes as much as possible, by instituting tight control tolerances on other aspects of the manufacturing chain, such as ensuring fit-ups are consistent.
The second is to improve the mechanised systems that are performing the welding to allow them to automatically perform the in-process control that an operator would typically perform. Examples of this already in existence are arc voltage control (AVC) and laser seam trackers. However, there is currently limited sensing for penetration in the single-sided arc welding process. Where root access is available, light sensing systems have been used to detect penetration, but there is not currently a mechanised solution that simulates a manual welder's adjustments to improve root penetration from a top-down view.
Work Programme
TWI have engaged in a collaborative project (AutoTIG, funded by Innovate UK, project number 104046) looking at automated control of the welding process, one element of which was the use of an imaging system to observe the weld pool in-process and adjust the welding parameters to improve weld penetration.
Welding was performed on thin sheet (2mm thickness) Ti-6Al-4V material, using a pulsed tungsten inert gas (TIG) welding process, applied by a welding robot. The joint preparation was a square edge closed butt. Welding was performed in an argon gas enclosure to prevent oxidation of the material, after it was prepared via an acetone degrease and abrasive sheet oxide removal.
The welding process was monitored with a XIRIS XVC-1000 welding camera and standalone software built by TWI software engineers using the XIRIS Source Development Kit (SDK). An example of the camera set-up is shown in Figure 1.
The software used brightness thresholding to identify different regions of an image, within two user-defined areas of interest (AOI). This works by identifying regions of an image that have digital brightness values above a user-defined value. The software then measures the height and width of this region in terms of pixel size, and this is then converted to a physical measurement by use of a known physical measurement as a scaling factor. An example image of the software is shown in Figure 2.
The software was used to study the weld pool width, arc width and arc height, as these were considered likely significant control parameters for the welding process that could be varied by a mechanised system. Weld pool length is unfortunately difficult to measure with a trailing camera system due to the presence of the arc and the parallax effect, so a side-view camera would be necessary as an additional monitoring system. This shows the difficulties of replicating the relatively free human movement around an arc performed during welding.
The software recorded the above measurements throughout the welding process, allowing time-based values of these measurements to be examined. For example, Figure 3 shows measurements taken during two welding runs. Figure 3a shows a "standard" welding condition, with no change in the welding parameters during the process. The measurements remain consistent once a steady state weld pool is established. Note, because this is a pulsed welding process, the overall "brightness" of the image varied between a low and high value, synchronised to the pulse current. Two methods of eliminating this double counting were considered. The first was a thresholding operation within the software that only records values above a certain limit. The second was synchronising the camera to the current, such that images are only taken during the pulse cycle. Off the shelf hardware exists to perform this.
Figure 3b shows the measurements recorded from a welding run in which the arc length was varied during the process from a short arc length, to a long arc length, and back again. The effect of this on the welding process can be seen. During the lengthening of the arc length, the weld pool increases in width up to a maximum value as the arc spreads, at which point heat transfer becomes less efficient. A similar effect can be seen in the arc width, as it spreads on lengthening. The arc length was measured precisely on the pulse element of the cycle, but shows no effect on the background element, as during this part of the cycle, the brightness threshold was focused around the tungsten electrode.
These measurements were further synchronised to the electrical parameters of the welding process, to determine the delay between changes in welding parameters and image features. An example is shown in Figure 4, which shows welding image measurements synchronised to welding current and arc voltage, in which the welding current was increased and in particular, the weld pool width increased as a result. As seen in Figure 4, the delay between change in welding parameters (of 5-10%) and change in image measurement was of the order of 0.5 seconds.
Figure 1: Camera system directed at the welding torch.
Figure 2: Screenshot of TWI software showing measurement of image features.
Figure 3: a) Welding measurements taken during a control pass; b) Welding measurements taken during a variation in arc length.
Figure 4: Image measurement and welding parameters recorded during a run in which the welding current was deliberately varied.
Having demonstrated that the image monitoring system could be correlated with welding parameters, it was then trialled to see whether the measurements taken could be correlated with the results of the use of varying welding parameters. To trial this, approximately 60 off welds were produced, varying welding parameters within the following ranges:
Parameter
Range
Units
Arc length
1.0 – 2.5
mm
Background current
50 – 66
Peak current
63 – 110
amps
Peak time
50 – 66
Travel speed
1.5 – 3.0
mm/s
Tungsten electrode angle
15 – 75
Degrees
Wire feed speed
0.6 – 1.0
m/min
Weld quality was assessed in two ways. Overall weld quality was assessed for defects against EN ISO 5817 Level B, with welds that did not pass this quality level not undergoing further assessment. There were a relatively small number of welds to which this applied. Welds were then assessed for penetration, as this was considered a suitable single-factor quality metric for assessment of the relationship between the welding image measurements and a "good" weld. Penetration was established via measurement of the root and cap width of the weld bead, and was defined as the ratio of weld root width (Wr) to weld cap width (Wc), calculated by Wr/Wc. "Good" welds were defined as those with a penetration value greater than 0.5.
Correlation of image measurements with penetration was then completed by producing welds with stepped steady state conditions, within which the welding parameter and image measurements were found to be consistent. This allowed graphical analysis of the relationship between the image features and penetration. Graphs of the weld penetration plotted against arc width, arc length and weld pool width are given in Figures 5-7.
As can be seen from Figures 5-7, there was not a significant correlation between either arc width or arc length with penetration, but weld pool width does show some correlation with penetration. Specifically, a minimum weld pool width of 10mm always showed some degree of penetration, if not a value of penetration greater than 0.5mm. This was therefore used as an intended control metric for automatic feedback control.
Based on the results described above, the TWI image analysis software was extended with a number of simple rules to control the welding parameters based on the image results. Specifically, a weld pool width measurement below 10mm resulted in an increase in the welding current of 5% and a decrease in travel speed of 5%. A weld pool width measurement greater than 12mm resulted in the opposite modification, with measurements between these two values maintaining a steady state. While image measurement occurred at the frequency of image recording (~25Hz), welding parameter adjustment was rate-limited at 2Hz, as this matched the welding current pulse frequency, and prevented a cascade effect.
The selection of welding control parameters was reinforced by the results of an "Analysis of Variables" (ANOVA) regression analysis that was performed using the welding parameters as inputs and the penetration metric as an output. A Response Surface was generated, which predicted changes in the output variable based on any given change in the input variable, and can assign a significance to each variable. The analysis indicated that the peak welding current and travel speed were statistically significant variables, whereas the background current, arc length, tungsten electrode angle and wire feed speed were not significant. The peak time was "partially" significant, due to its cross-relationship with peak current.
The control system was demonstrated to work on existing recorded videos of the welding process, generating the required changes to control parameters based on the observed weld pool measurements, but has not yet been applied to a control system with fully integrated feedback control. This is intended as further work.
This work was performed as part of an InnovateUK funded project, with Rolls-Royce plc, Cyberweld, Graham Engineering and Loughborough University, under project number 104046.
Figure 5: Graph showing relationship between measured arc width and penetration.
Figure 6: Graph showing relationship between measured arc length and penetration.
Figure 7: Graph showing relationship between measured weld pool width and penetration.
Avatar Rob Shaw Principal Project Leader, Technology
Rob Shaw is an IWE-certified Welding Engineer, with a background in metallurgy, who works at TWI undertaking development of welding procedures for arc-processes, both manual and mechanised. He has a particular interest in the nuclear and power sector, which necessitates welding of more exotic materials, such as nickel or refractory metals.
